keep in mind i do not have a cam (vid inside) - FirebirdV6.com/CamaroV6.com Message Board
  • keep in mind i do not have a cam (vid inside)
    http://youtube.com/watch?v=BgavXAhuVqk
    so i have no idea
    Re: keep in mind i do not have a cam (vid inside)
    Originally posted by MAROA4L32
    obviously someone broke into your car and installed an extremely lopey cam, duh
    but seriously is your brake booster disconnected or something? did you run out of gas?
    1999 v6 Camaro M5
    Automatic to Manual converted
    Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
    !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
      lol possibly but they shouldve asked i have my own cam i wanna put in
      and nah i have a half tank in it
        vaccum leak?
          That's my vote too, a vacuum leak. I know I seafoamed with my cutout open once. My god that was such a loud violent sound with the brake booster disconnected. :)
            My car does something similar and it turns out I'm not getting but 7-10 PSI fuel pressure.
            Originally posted by LETZRIDE
            I've never touched a rear end before
              When my brake booster was disconnected i just idled high. I vote misfire, possibly multiple.
              1996 Chevrolet Camaro
              1995 Buick Park Avenue Ultra
              --Appearance Moderator--
                Bad IAC valve? (idle air control)
                • Andy H
                  Transmission removal help!!
                  by Andy H
                • 2.8 Bird
                  Abs inop
                  by 2.8 Bird
                • fishin
                  by fishin
