Hard Starting - FirebirdV6.com/CamaroV6.com Message Board
Hard Starting
  • Hard Starting
    I'm trying to pinpoint why my car is a pain in the butt to cold start (and sometimes warm starts) so far I've changed the fuel filter, the spark plugs, the wires, the cap things they plug into (long day at work), Sea Foamed the entire engine using the guide I found on here.
    Checked the spark plugs for any oil/soot/whatever after 1k miles and they are still new looking. I am completely out of ideas, even Chilton's has run out of things for me to check.
    The engine turns over quickly when I turn the key like it wants to fire up but doesn't. I release the key for a second and try again, 50/50 chance it'll fire right up. Or once in a while get to 500 rpms then die out, or wake up like a grumpy old man. When I finally get it started she runs surprisingly smooth. You can sit in the car and not even know it's running.
    Random question, is the oil pressure needle supposed to randomly bounce around at 80?
    It's a '93 Firebird, btw. V6 of course. :tup:
    Re: Hard Starting
    93 firebird ftw. Hows the battery? Fuel pump?
      Re: Hard Starting
      I would check the fuel pressure, especially while you are cranking it. Maybe the regulator went out, and it's taking a while for the system to re-pressurize itself.
        Re: Hard Starting
        could be a timing issue
        1999 White Pontiac
        A4, slp loudmouth, pacesetter headers, ws6 wheels, SLP cold air kit, wings west kit
        :rock:
          Re: Hard Starting
          i agree with rob bell, start there
            Re: Hard Starting
            Thanks for the pointers guys. The battery is brand new, as are the bolts, the cables are a bit corroded but nothing drastic.
            D'oh. I knew I forgot to check something. :spank: Time to go rent me a pressure gauge.
