turn signal - FirebirdV6.com/CamaroV6.com Message Board
turn signal
  • turn signal
    ok, this is not on my camaro, but rather on my beater truck, a 94 S10 blazer.
    my right side turn signal recently stopped blinking. the left works fine but the right doesnt work at all. it hasnt worked at all this past week, expect for one day when it worked fine (repeatedly turned the vehicle on/off just to make sure). after that day, it hasnt worked since. the hazards work fine. all the lights come on too, and come on as soon as the switch is thrown, they just dont blink. would a blinker cause only one side to not blink? i thought you would lose both sides if the blinker quit working? any ideas??
    Maybe it's a dual filliment bulb, and one of the filliments burned out?
      nope.. thought of that already.. tried a new bulb too... like i said, they blink for the hazards fine, just not the turn signal...
        Check the wiring next.
          ahh try replacing the turn signal relay.
          usually pretty cheap. like 10 bucks i think.
          *Matt
            well how bout that.. today it worked again.. but only comin home from work, not goin to work or going to pick up lunch... im hoping its not a wiring issue cause that would just be a pain in the ***... guess ill start easy with the flasher and hope it keeps workin...
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
