There's a rod that's connected from the ignition lock to a big switch located on the top of the column about half way down to the floor ... take off the dash piece under the column and feel around up there for it ... mine got jammed up once and all I needed to do was wiggle the shaft and it came free ... good luck !!
MY KEY IS STUCK IN MY IGNITION! HELP!!!
I say still try and jiggle the wheel and see if it comes out....
if the buttong feels wierd tap it a bit with a hammer.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
i wouldnt be spraying wd40 in it...its not going to help.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Thanks for all the help. The wd 40 did help, i left it sitting soaking on it through the night, got up in the morning played with the ignition some more, moved it back and forth like 100 times and it budged it moved to the middle. Then i pushed back really hard and it worked. Got my key out. But ever since its been acting up. Now my car doesnt want to start i turn the key and it makes a hissing noise, but after i play with the ignition for a little bit its starts, its weird. I think ima just get a new ignition, problem is im looking at them and it gets into this whole VAT key thing that i need. How can I read what type of VAT key i have?1994 Pontiac Firebird M5<br />Flowmaster 80 Series/dual pipes<br />Magnaflow High Flow Cat<br />eBay two piece intake<br /> <a href=\"http://www.cardomain.com/ride/2112560\" target=\"_blank\">http://www.cardomain.com/ride/2112560</a>
Originally posted by 94firebirdteal:
turn the key and it makes a hissing noise~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
My key reads 887, when i test it, or something close to that. Take a meter, and use the ohm setting, it looks like the unside down U on the meter. Take your meter and hold one lead on one side of the chip and the other lead on the other side of the chip. On the metal parts of the chip "the center". And the reading you get is the resistance of your chip. The hissing you hear is a short you have created by shooting wd-40 into your ignition. Also you dont have to get another VAT ignition, you can simply soilder a resister inbetween the wires and get a regular one. [img]graemlins/banana.gif[/img] Let me know if you need more help.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Originally posted by Dojo2000:
</font><blockquote>quote:</font><hr />Originally posted by 94firebirdteal:
I have heard it prime, and hear a little "motor" sound, but NEVER a hissing sound.
Originally posted by victimizati0n:
</font><blockquote>quote:</font><hr />Originally posted by Dojo2000:
I have heard it prime, and hear a little "motor" sound, but NEVER a hissing sound. </font>[/QUOTE]Where was this hissing sound coming from. The ignition or some where else?<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Considering what ive read about this, and what you've done, and the hissing has just now started, and your ignition problems have just begun.... I think your wd-40 f*cked it up. Spraying any type of cleaning liquid or lubricant into a majorily electrical area is commonly a bad thing. That would have been my last and final option if nothing else worked. Good luck though.1996 Chev Camaro RS 3.8<br /><a href=\"http://www.cardomain.com/ride/2233257/1\" target=\"_blank\">http://www.cardomain.com/ride/2233257/1</a>
were you able to understand how to read your key with a meter?<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
i went to radioshack and they couldnt help me out, i would have had to buy the tester which was 25.991994 Pontiac Firebird M5<br />Flowmaster 80 Series/dual pipes<br />Magnaflow High Flow Cat<br />eBay two piece intake<br /> <a href=\"http://www.cardomain.com/ride/2112560\" target=\"_blank\">http://www.cardomain.com/ride/2112560</a>
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
