Serious Problems Part II: Please Help.... - FirebirdV6.com/CamaroV6.com Message Board
  • Serious Problems Part II: Please Help....
    Allright I have more info guys. My car just seems like it is falling apart.
    :mad: My exhaust smells really strong.
    :mad: It makes a weird wheezing vibration sound especially during tight shifts (A4).
    The muffler is a take off and they shouldnt do that.
    :mad: The muffler pops a while after the car is off.
    :mad: The muffler is not quiet, and I have a flowmaster resonator in line. It should be silent?
    :mad: The exhaust was filled with around a cup of water when I took pipe of at the cat
    :mad: My exhaust smokes sometimes white smoke. usually when engine is cold.
    :mad: The car holds of with the gas down for a while and then surges. Like If i go from 20% throttle to 50% it stays like its at 30% and then shots to 50% and gets a huge power boost.
    :mad: The car is running not as smooth as it usually does.
    Things do to no avail:
    *Replaced Plugs
    *Replaced Wires
    *Seafoamed Twice
    *Oil Change
    I have heard things like leaking coolant/blown head gasket. What could be wrong and what should my next step be? I asked about a compression test, would that tell me anything? Thanks for all your help so far,
    John
    Oh, I forgot the main raeason I posted again.
    I figured out my fuel economy. With premium I got 15.5 MPG!!!!!Thats worse than an 8. WT?
      Definitely do a compression check throwing any codes for o2s or anything?
        Nope. No codes. What should the compression gauge read? Thanks.
          Just a wild guess, maybe a leaking fuel injector? Any one sparkplug that's fouled (period, or more so than the others?) Good luck, I'll keep poking around and see if I can come up with anything else.
          Jon
          1994 3.4l M5 Camaro<br />Magnaflow Catback, 245/50ZR-16 BF Goodrich g-Force T/A KDW\'s<br />\"If you have the power to do it, then do it.\"
            I don't know the exact compression but it should be within a certain percentage of the cylinder next to it.
            it shoud read
            cylinder 1 120 psi
            Cylinder 2 111 psi
            Cylinder 3 108 psi
            Not
            Cylinder 1 120 psi
            Cylinder 2 35 psi
            Cylinder 3 111 psi
              All the plugs looked normal.
              I am leaning toward blown head gasket, or cracked. What do yall think? Thanks for the specs MustangEater. Ill look in the manual for the exact. Isnt it within' 10%? Has anyone blown a head gasket, what happend? Thanks again everyone.
                popping and vibration, and you said it surges like it get a huge power boost I say it's a coil, could be a pcv thing but MOS DEF it's a coil have you checked them?
                ---Niño---<br /><i>95\' silver 5 spd</i>
                  Nope. How do you check coils? It also has a starting problem that comes and goes. It sounds health, just wont fire up. I have replaced PCV valve as well. Thanks,
                  John
                    Update: I ran a compression test. Everything looked okay. Numbers where around 170-180 on all cyclinders. I did notice the gauge would start low, and build every compression stroke on some cylinders and on others it would start low, jump to like 100 and then continue in a step manner to 180. What does that mean?
                    Also, back to the coils. How do you find out if they are good, bad, and/or going? Thanks!
