well today i was taking the bolts out of my water pump and i unscrewed a bolt and about 15 ounces of water came out of the bolt hole any ideas ha
haha uhmm dont think that was supposed to happen
Re: haha uhmm dont think that was supposed to happen
put the bolt back in and top off the fluid in your radiator? why were you taking the bolt out in the first place?Dave:
00 Supercharged Camaro - RIP
97 Turbo Camaro - Sold
you dont have to take the waterpump off the timing cover, there are 2-3 bolts that only goes trough the pump and into the cover. If youre not shure about who, just take them all off and gently push the timing cover off whit the pump still on it, and when its off/loose, put the "pump to timing cover bolts" back in so the pump doesnt loosen from the cover. -less work. :) Just remember to use some type off silicone stuff on the bolts that goes into the water. :)
Originally posted by MAROA4L32well im puttin a new timing chain on so you have to take the water pump to take the timing cover off stupid 3.4
I just did a cam in my car. We took the timing chain cover off with the water pump still attached. The pump needs to be replaced now :(~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Originally posted by UDLOSE98some of those bolts retain coolant directly behind them.... not anymore.1997 Camaro LS1 RS
1994 Camaro - Sold
1999 Trans am Vert - Sold
A Few Mods....
what cam are you usig now, did you improve any hp's? i want to do a cam swap too and i don't know what`s the best cam whitout tuning the ECM... i guess i need a camshaft(any ideasfor a daily driver with auto tranny??), new lifters, timing chain and a set of gaskets hmm
update
got everything off and out of the way got the timing cover off and my chain was so loose it was rediculous so i put my new comp timing am i going to gain anything?
2002 Navy Blue Metallic Blue Firebird A4
Pure stock (Hey, just bought it 11/07)
