anyone ever taken off the LIM from a 3.4? theres 7 bolts holding it down right? and theres 3 studs that you need to lift the LIM off of? is this correct?
Oil no, coolant you will leak some but its pretty much unavoidable unless you drain the actual block, not the radiator. Either way, as long as you dry it all up real good with some shop towels and some brake clean. Make sure you use sealant on all of the bolts too.
