car keeps dying during start up - FirebirdV6.com/CamaroV6.com Message Board
  • car keeps dying during start up
    when I start up my car the car rpms just jump up and down now if I give it some gas during start up the car will run fine any ideas on whats the problem
    Re: car keeps dying during start up
    check your fuel filter
      and how would I do that Im not sure where it is or do I have to raise the car up if its a lot of trouble I would rather take it to the shop my car is a 98 btw
        just use a jack and its right under the car... easy to get to.
        Welcome future UK stars... Darius Miller, Deandre Liggins, Kevin Galloway, Josh Harrellson
          yeah, or drive it up on ramps
            i used ramps alot easier.
              Yeah, it's on the driver's side of the car, near the rear.... in front of the lower control arm. Just follow the fuel lines. It's a very easy change. Takes around 10 minutes for me counting the time it takes to jack it up with a crappy floor jack.
              When you get it in the air, make sure it's supported by stands, and wear some safety goggles and old clothes. Locate the fuel filter, when you find the line going into the filter, you'll find a plastic clip on the end of the line that hols the line to the filter. There are 2 tabs that need depressed to remove the line from the filter, they are 180 degrees apart (opposite sides of the line). Push those tabs in and pull the line away from the filter.... do the same on the other end of the filter as well. Remove, replace, put it all back together.
              ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
                well I just put some water in my battery and car started up fine I came up with that idea because it was a while since I put water in my battery and when I locked my car the alarm sounded like it was near deaf
                  Fortune: Do not smoke when change fuel filter, no good for health.
                  Seriously, I was amazed of the crap that was in the fuel filter, looked like fine glittery sand.
                    yeah if your fuel filter is fine check the crank shaft pos. sensor or cam sensor which ever one its called jus check the wires and make sure theres not any oil or other types of fluid in the plug its self
