Tech is wrong? - FirebirdV6.com/CamaroV6.com Message Board
Tech is wrong?
  • Tech is wrong?
    I was out in the garage cleaning up, and I found my old thermostat. I always thought that it was a 195, even thought the tech database says its 180. Well anyway my thermostat said 195 on the bottom of it. I was just wondering if I have a freak 99 or what?
    Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
    I'm pretty sure all the 4th gens, at least the 3.8's all had the 195* thermo stock.
    The thermo mod started out using a 180* I think, but then went to the 160 hoping for a more drastic effect.
    EDIT
    Although, going though my books, I can't seem to find anything right now that backs me up. lol
    [ January 07, 2003: Message edited by: Distephano ]</p>
    1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
      yeah the tech database is wrong. all 3.8's come stock with 195*
        hmmm..... you guys SURE about this?
        I mean SURE?????
        ie: 97 thermo part # is same as 00...
        are there any markings on the thermo's?
        If so, I will make the change.
        Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
          i can snap a pic of my stock 2000 thermo that says 195 if you need that much proof keith
          [img]tongue.gif[/img]
          but seriously, yes it's 195
          2011 Camaro LS 6M, in black.
            <blockquote>quote:</font><hr>Originally posted by Magnus:
            [QB]hmmm..... you guys SURE about this?[QB]<hr></blockquote>
            My stock thermostat was marked 195, and autotap consistently reported a steady 195 reading (unless I got on it, or was sitting still), on my '98. Until I put a 180 in it.
            \'98 A4 Camaro v6-&gt;v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
              Both my 2000, my mom's 2000, and my current 2002 all came with 195 stats. Stamped on the back of it!!
              2002 5-spd NBM Camaro
              Details: www.1lev6.com
                From the GM parts list:
                95-97 GM 24506986 (AC Delco #131-115)
                98-01 GM 24505924 (AC Delco #131-120)
                A couple of years ago I listed the 98 has having a 195, and got *****ed at by owners who said they had a 180 - so I changed it. GM lists different part numbers, so you tell me.
                Raven
                  Robert, perhaps there's just a slight design change in the thermo's. GM did do a lot of stuff between 97 and 98.
                  • Andy H
                    Transmission removal help!!
                    by Andy H
                  • 2.8 Bird
                    Abs inop
                    by 2.8 Bird
                  • fishin
                    by fishin
