Where's the Oil Sending Unit? - FirebirdV6.com/CamaroV6.com Message Board
  • Where's the Oil Sending Unit?
    I have a 99 camaro and I was wondering where's the oil sending unit?
    Black 99 M5 Camaro \"6BANGER\"<p>Sport Appearance Package, Whisper Lid, SLP Cold Air Kit, K&N Filter,Dynomax Custom Cat-Back, BMR STB, Jet Stage II Module, Centerforce Dual Friction Clutch, Hurst Shifter with Custom Short Stick, RKSport 2\" Drop Springs, SS Hood, Poly Tranny Mount & TA Bushing, SLP 3.42 Gears with LSD, All Amsoil Synthetic Lubricants
    If you're talking about oil pressure sending unit, it should be on the back of the intake manifold near the block/manifold junction.
    If you're talking about the oil level sending unit, it's a fitting in the oil pan.
    Big cam. Big stall. Big nuts.<br /><br /><a href=\"http://www.streetlethal.net/vids2/joenastycam.MPG\" target=\"_blank\">Idle/Rev Clip.</a>
      <blockquote>quote:</font><hr>Originally posted by RamAir95TA:
      <hr></blockquote>
      The oil pressure sending unit on a 3.8L is located on the front of the block near the oil filter. It will be a small cylinder shape with wires connected to one end.
      ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
        The reason why is because I want to get an auto meter oil temp gauge and I want to know where to pick the temp up at. Do you guys know where?
          Yea, if you look at your oil filter on the front of your block from the top, the sender is withing 6 inches from there, just a little above and to the driver's side of the filter. I believe the connecter has some green on it, but might be wrong. About 3 or 4 inches long with a harness plugging into it.
            so thats where I tap into for oil temp.........
