Running on Fumes? - FirebirdV6.com/CamaroV6.com Message Board
Running on Fumes?
  • Running on Fumes?
    It seems that I saw a 02 Firebird has a 15.5 gallon tank?
    How did I put 15.7 gallons in it?
    406.4 Miles on this tank... 26mpg
    2002 Navy Blue Metallic Blue Firebird A4
    Pure stock (Hey, just bought it 11/07)
    Re: Running on Fumes?
    I don't know what the question is, how you got .2 more gallons in your tank?
    Maybe you just squezed it in there.
    At 2.89 you better get all you can get.
    I think it was 3 something around here the other day. Gas is bullsh*t :rant:
      yeah its like 3.50 for premium in the B LO
      maybe the tank is 15.5 but the tank and filler neck is like 15.8 total?
        Because 99+ F-bodies got a 16.8 tank.
        https://www.mygmlink.com/pdf/go2cont...99firebird.pdf Page 320
        http://shbox.com/pdf/manuals.html Manuals
          only 98 and below fbodies had a 15.5 gallon tank.
          plus, most gastanks only will to 80% full at the pump
            :banana: Hell Yeah, that means I can try for 425 next time!!!:banana:
              your going to fry you pump...
              1999 Camaro Z/28
              1973 Firebird Formula
                btw that brings your mpg down.... ftl.
                  i dunno, 75% of the time, my car is on E, and i havent friend my pump yet (i usually only put in a few bucks here and there)
                    if you run out of gas though it is very easy to fry a pump
                    and running on E all the time isn't the best
                    1999 Camaro Z/28
                      how so if you have less gas=less weight
                      1997 Camaro LS1 RS
                      1994 Camaro - Sold
                      1999 Trans am Vert - Sold
                      A Few Mods....
                        the more the car weighs the less mpg you are going to get
                          thats not what i mean.
                          in his first post he said he was getting 26mpg but now that we find out he has a bigger gas tank his mpgs are actually less. therfore ftl.
                            Not really, depending if he was going on miles per tank or miles per fill up. Miles per fill up is more accurate. Fill up, drive around normally, fill up again (both times till the pump stops) then take how many gallons it took into miles driven.
                            But its true, running that low too much puts strain on your fuel pump.
                              No, total mileage per tank divided by the amount of gallons you add to the tank
                              400 miles - 4 gallons, 100mpg etc...
                              And, "they" say your supposed to keep your tank above 1/3 full to prevent overstressing the fuel pump...
                              *Matt
