I ran my car today no diference in the 1/4 no et no mph and not worth my money dont waaste your money
HYPERTECH = TRASH!
How long had it been programmed to your car when you ran? Also, were the conditions the same today as the last time you ran your car? There's alot more to an ET than just doing a new mod, and running it. Weather plays a big role, and alot of other things.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
Dyno testing a mod that yields "small" improvements is the only way to go for accurate results. Do a before and after test the same day, or have the results corrected for the conditions.1995 Firebird 3.8 A4, 140,000 miles and going strong<br />Basically Stock, college=poor <p>Junior Mechanical Engineering Student: Milwaukee School of Engineering; Cpl, MN Army National Guard...just got promoted :)
im interested for one for a 0098 Jeep Grand Cherokee 5.9 Limited<br /><br /><br />MODS:<br />180* t-stat, K&N FIPK, mopar ECU,<br />mike leach long tube headers+3\" y-pipe, 3\" all the way out flowmaster 50 series, mopar magnum 2bbl m1 intake manifold, APS 52mm throttle body, powerslots, 2 JL 10w3\'s
<blockquote>quote:</font><hr>How long had it been programmed to your car when you ran? Also, were the conditions the same today as the last time you ran your car? There's alot more to an ET than just doing a new mod, and running it. Weather plays a big role, and alot of other things.
--------------------<hr></blockquote>
This is a good point. It would be best to take the programming out and make a few passes and then install only the tuneup and make a few passes and then compare. Also, if you've changed the shift points and they're too high, you could be losing ET.
While I think HP gaines are overstated by most manufacturers, to be fair you have to try before and after in as close to identical conditions as you can. I could easy show the HPP or Jet losing a bunch of ET by running stock when it's 50 degrees out and no humidity and then running the tuneup when it's 85 and humid. It doesn't take a bunch of weather change to make your ET +/- a tenth or two.
Ron
I'll be doing that back to back testing at the end of the month when our track opens...
[ March 17, 2003: Message edited by: 67-03 RIP ]
[ March 17, 2003: Message edited by: 67-03 RIP ]</p>I know - Camaro 67-02.. 2000 Camaro V6/A4 Black T-Tops<br />1969 Camaro 350/PG 12.69 @ 102.5 1966 Chevy II Wagon 283/PG Destined for NHRA stock eliminator.
<blockquote>quote:</font><hr>Originally posted by arnaldo:
HPP3 made me slower as well.. anyone want to buy mine? heh<hr></blockquote>
I want it! in about 2 weeks [img]smile.gif[/img]-Chad<br /><a href=\"http://members.cardomain.com/chiknz\" target=\"_blank\">2001 3.8L A4 Camaro</a>
Drag racing has more to it than just overall power, your actual racing consistancy has a lot to do with whether or not you determine the gains from a mod or not. I assume you haveny autotapped or dyno'd your car?2002 5-spd NBM Camaro
Details: www.1lev6.com
Not to mention the other gains such as adjustable fan temps, speed limiter adjustment, etc! ;)Jason McCallister, Founder & Webmaster<br /><a href=\"http://www.wtfba.org\" target=\"_blank\">West Tennessee F-Body Association, Inc.</a><br /><br />2000 Camaro - <a href=\"http://www.wtfba.org/site/view_member.php?ID=68\" target=\"_blank\">Details</a>
<blockquote>quote:</font><hr>1999 Pontiac Firebird A4
mods:
Poly tranny mount, 3.73's with lsd, NX wet kit, whisper lid, HPP III, FTRA, 2000 y87 computer,stock piping with No cat with rear 2.5 in and out dynomax super turbo, K&N Filter.
To come: 1.75" drop kit with new shocks
14.8 best E/T
IMPORT KILLER
<hr></blockquote>
Duke - You weren't on the NOS were you? I'm pretty sure the HPP says not to use it with power adders. Good luck in the testing - try one thing at a time (like stock 1-2 shift and the +2) and when that gets as good as it can, move on to the next (2-3 shift). You might just get a personal best yet.
RonI know - Camaro 67-02.. 2000 Camaro V6/A4 Black T-Tops<br />1969 Camaro 350/PG 12.69 @ 102.5 1966 Chevy II Wagon 283/PG Destined for NHRA stock eliminator.
Rip's right. If you're doing the juice, you don't want to be running the the tuner part of the HPP. The programmer is advancing the curve for higher octane fuel. If your using your NOS, I'm sure you'll want to be going in the opposite direction (retarding the timing). Mixing the two can lead to some serious problems. [img]graemlins/crybaby.gif[/img]Zobe
