can anyone tell me what this does, and if its worth getting. If so, where can I get one??
throttle body spacer
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
Isulates the TB from heat of intake, way to do coolant bypass on the 3.8l, if you have a 99+ goto www.zzperformance.com .95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
I've got one on my 95 with the 3.4L and I never noticed a difference. It does keep the throttle body cooler so that means the incoming air can get a little closer to the combustion chamber before hitting hot metal, which is the intake now instead of the TB. But, by itself it can't make much of an improvement. It helps in an additive manner. The more you modify your intake and exhaust, the more it can do for you. I already had a K&N intake and a descent exhaust so I thought it wouldn't hurt. I'd say go for it.
As far as where to get it, watch the for sale section. Somebody might have a used one or do a search for Dee's TB spacer and see if he's still making them. Good luck.95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
y not check out my install guide in the review submission section?- \"So you have something to look at when you\'re talking to \'em\" - <br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=296916\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=296916</a>
