fuel filter - FirebirdV6.com/CamaroV6.com Message Board
fuel filter
  • fuel filter
    where is it
    mines going bad and its starting to annoy me
    Re: fuel filter
    It under the car attached to the frame rails just below the driver side back seat.
    Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
      Re: fuel filter
      big metal cylinder.
      WAWA-A-HOLIC
        Re: fuel filter
        get a pair of needle nose pliers for one side, 20mm (or 13/16") and a 16mm (or 5/8") wrenches take care of the other side. And fuel filters are exposed to the elements, so a can of penetrating oil won't hurt either. If you know it needs changing take care of it ASAP or you'll strain your fuel pump.
          Re: fuel filter
          What other steps is there? Do you need to have low fuel(almost E) so that much fuel doesn't come out?? And i'm assuming a catch pan for what spills out right? I'd like to do this to my also Firebird as I do not know when or if it has ever been changed. Thanks
