Why is my car smoking? - FirebirdV6.com/CamaroV6.com Message Board
  • Why is my car smoking?
    White smoke coming out of tail pipes...usually happen about 2 or 3 minutes after starting and lasts no more than 10 minutes. It is a white, almost oderless smoke (although you CAN smell it, but barely)...looks alot like exhaust on a really cold day.
    The inside of my exhaust tips are wet when this happens.
    The smoke IS NOT constant...it comes out in puffs. The engine sounds normal and is running perfectly smooth.
    Is this just a sign of aging?
    BTW, I know it ISNT oil burning...it hasnt rained lately, and it hasnt been doing this for more than a few weeks although it seems to be slowly getting worse.
    TIA
    Adam
    <a href=\"http://members.cardomain.com/adamon6thstreet\" target=\"_blank\">1996 Firechicken</a><br /><b>15.19@91.61</b><br /><i>It Rocks Your Panties</i><p>Daily Driver: <a href=\"http://members.cardomain.com/pimpnon6thstreet\" target=\"_blank\">1990 Pontiac Trans Sport SE</a><br />Most recent mod: Mounted an Evan on the dashboard.
    Its called condensation - its just water man it happens to all cars when it gets cold.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      70* F isnt cold...i know condensation:
      <blockquote>quote:</font><hr>...looks alot like exhaust on a really cold day.<hr></blockquote>
      it LOOKS like that...but it isnt...it smells sorta like propane burning...?
        Check the coolant just to be on the safe side. Oh nad also check the oil to make sure there is no water in the oil and look into the TB to make sure no water is in there also. Good Luck!
        2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
          just pray you dont have what i did, but you say it only last 10 minutes. my car smoked day and night and cost me a grand to fix. you know what my car is still smoking.
            <blockquote>quote:</font><hr>Originally posted by nino:
            just pray you dont have what i did, but you say it only last 10 minutes. my car smoked day and night and cost me a grand to fix. you know what my car is still smoking.<hr></blockquote>
            ?? What was the inital cause of the smoke ??
            -Marc
              <blockquote>quote:</font><hr>Originally posted by toast:
              Check the coolant just to be on the safe side. Oh nad also check the oil to make sure there is no water in the oil and look into the TB to make sure no water is in there also. Good Luck!<hr></blockquote>
              I 2nd this. Coolant could be leaking thru the cylinder head gasket or a crack in the head or block. A compression test could isolate the problem cylinder. Check ur oil to see if it's milky.
              1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
                What is probably happening is that you are getting alittle bit of oil threw your rings and it is buring up which causes the smoke it isnt a huge problem but it will only get worse with time i had the same problem and i was told that it was a common problem with gm engines
                  i too thought that was my problem. then i found out i had a broken valve guide.
                    sounds like your car and adam's car need some nicotine patch. ;) :D :D
                    <i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
                      Had this problem once on a 2.2l engine. There was a minute crack in one of the spark plug bosses that allowed coolant to seep into a cylinder. I eventually figured it out when the crack enlarged and I had coolant spitting out of a spark plug boot.
                      You can achieve anything for which you are prepared to pay the price.<br /> --ATTILA THE HUN
                      • Andy H
                        Transmission removal help!!
                        by Andy H
                      • 2.8 Bird
                        Abs inop
                        by 2.8 Bird
                      • fishin
                        by fishin
