160 thermo? - FirebirdV6.com/CamaroV6.com Message Board
160 thermo?
  • 160 thermo?
    I got the hypertech and it says that it works better with the 160 thermo. I have a 2000 m5 and I think the the 160 doesn't work right on the newer models but will it work right for me or is the 180 better for my car.
    thanks guys [img]graemlins/burnout.gif[/img]
    look on one of the v8 boys face when he finds out he just lost to a v6 \"ha ha priceless\"<br />2000 camaro Mods: Slp cai,kn filter,whisperlid,talor spiro wires,ngk plugs, rk sport headers, 3\" Borla cat back exhaust,3.73\'s with lsd,pro 5.0 shifter,2002 Corvette wheels, lowered and 1\"1/4,painted calipers black with chrome camaro decals, hypertech programmer
    This has been described in detail by Dominic, member #35. Do a search and you will get all the info you need.
    2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
      It's a bad idea for a lower thermostat because your car will always think that it hasn't warmed up, so it will run a lot richer and you will get poor gas mileage from it since it is not running efficiently. But of course do what you want with your car, good luck.
      2000 bird y87 M5
      2000 Y87 Bird M5 with mods<p><a href=\"http://www.vzavenue.net/~ngeorg/\" target=\"_blank\">http://www.vzavenue.net/~ngeorg/</a>
        <blockquote>quote:</font><hr>Originally posted by v6revenge:
        <hr></blockquote>
        you can run the 160 in a 2000 model without any problems at all, no resistor or any mods necessary to make it work trouble free. COnsider yourself lucky [img]smile.gif[/img]
        2002 5-spd NBM Camaro
        Details: www.1lev6.com
          What about with my 99, will a 160 thermostat work fine?
          I have heard it helps if you drill two 5mm holes to let a little bit of coolant through at all times, would this be advisable if I were to go to a 160, or should I skip the 160 and just drill out the 180 stat, or get a 160 and forget drilling....so many choices.
          BTW, this is my first post here, I've been part of fbodyv6.com and have been watching the forum but never felt like registering until now ;)
          7\"TV, DVD player, WW ground effects<br />2800 stall, aluminum DS, NX wet kit<br />15.39 (G-tech) stock w/3.42 LSD
