Just had a thought for a free mod on 3.4L... please tell me if you think its credible - FirebirdV6.com/CamaroV6.com Message Board
  • Just had a thought for a free mod on 3.4L... please tell me if you think its credible
    I jsut had a thought.
    What if I unhooked the EGR where it connects to the upper intake plenum, and unhooked the vacuum line right behind the TB?
    I know it woudl cause and idle leak but wouldn't it also allow more air flow under hard acceleration? And we know the intake on the 3.4L sucks.
    Anyone think this would work on a 3.4L?
    Would this be basically blocking off the EGR?
    Blocking off the EGR would definately help with freeing up some horsepower (not much but every little bit counts). After all the bolt ons and some internal work I'd start putting my Fbody on a diet and remove the A/C (as well as bypass the EGR and emissions items. When the time comes to test emissions, I just re-install them).
    But is what you said credible?
    I'd try it [img]smile.gif[/img]
    [ January 08, 2003: Message edited by: Liquid Silver ]</p>
    <b>Sean: 1994 Camaro daily driver</b>
      But I am not talking of blocking of the EGR, but a track only mod of allowing the intake leak.
      I woudl basically be unhooking the EGR, and letting the motor jsut suck in air though the EGR hole.
        Running motors lean will produce some more power but with motors these days controlled by computers, I don't think it would be a good idea. Your talking about creating a 'permanent' vacuum leak. Under hard acceleration, it would be somewhat beneficial but under normal driving, it would hurt you not to mention your gas mileage. But if you rigged a valve so you could control when it was open and closed would be better. Either way, I don't think it would be worth the effort.
        Jim
          Was going to be a track only mod, reason why I don't think I woudl run lean because we have no MAF, and the O2s would regulate the running lean.
          hehe I am sure I woudl be idling 2-3k, doing this, just a thought. Would be more air into the motor.
            try it and let us know [img]smile.gif[/img]
              EGR doesn't operate at WOT, if that's what you're thinking. If you're just wanting to smooth the intake airflow out a little bit, I doubt it's worth the effort. Also, air would most likely just leak out of the hole for the EGR, instead of into it. Intake leaks aren't good, ya know?
              [ January 09, 2003: Message edited by: Fin ]</p>
              2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
