maybe I missed it when i searched for it but. is it worth puting bigger injectors in my 3.4 with the factory fuel rails ?
injectors
Re: injectors
not unless you like running rich and wasting gas.
If you had engine work that made it so you would need the extra fuel then yes
Re: injectors
Originally posted by metallica_mikegok i have never had such a small engine before, i have only had v8's but it sound like from what im reading it is a challange to get some power out of these engines
3.4s just are limited on tuning which holds them back. You can still make plenty of power with them though
Re: injectors
they Are also HIGHLY limited by the intake and heads...now that said I put injectors 18lb/hr injectors in my 3.4, she ran a tad rich but boy when I stepped on it she evened right out and went like hell. do 18lb/hr injectors CAI, cat-back exhaust and that will give you a bit more in the balls department.
damn I just realized 1 thing...Is this an auto or manual?
Re: injectors
doing injectors might f'up your trans...it lower my idle quite a bit, actually sounded like I had some kind of sexy cam.
Now understand befor you dig in...building up a 3.4 IS NOT like any other engine, you can throw parts at it. 300hp at the crank is my goal with mine as well. you'll need to upgrade to a 3x00 top end to really see any improvement being the heads on our 3.4s are the same as what you would find on a old S-10 2.8. but swapping the top end requires new pistons, modified timing cover, modified headers, and a ton of patience.Last edited by nightrider2; 02-12-2008, 08:48 PM.
Re: injectors
If you go 3x00 the valves are already freaking huge for the head. besides that it sounds like you have good plansLast edited by nightrider2; 02-12-2008, 09:00 PM.
Re: injectors
I my self have gone all out in both fields...I have my 3.4l Camaro fully built 3.4 awaiting final completion and a growing mod pile for my T/A with a 67-72 year 350SBC
Building the 3.4 in my mind is special cause its not common...I started my build a year ago when the plausibility was still in doubt and there is only 1 running car I know of.
I stopped driving...3 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...4 weeks ago
