For anyone who has one... Which one do you have and how satisfied with it are you?
Air/Fuel gauge
Hope you're planning on getting a wideband sensor, otherwise you'll be looking at junk. I think Jessica ended up getting rid of hers because it was going all over the place (as a narrowband sensor should).Matt
1998 Mystic Teal Camaro M5
All it will tell you is if you're at 14.7:1 or not. You'll be richer than that at WOT, but you won't know by how much. Without a wideband sensor it's useless.Matt
Originally posted by SilverBirdSeven:
ok thanks guys. that aem set is really expensive, but, I guess youy get what you pay for.
I was really just wanting something to show the change when I do different air intake work.
the only one thing i don't like about it is its only reads to down to 11.0:1 but reads up to 17:1 i wisha it would read from 9:1 to 15:1
other then that i really really like itwww.turbov6camaro.com
1997 3800 Series II Camaro
Really? The one I saw read from 10.0:1 to 18.5:1
Where did you get yours?www.turbov6camaro.com
the narrow band a/f wont tell you changes like you described.
they are light shows for your dash. not used for tuning.
I have one, it is a show, unless you are going WOT, then they stop and show a reading.
I have an autometer Phantom gauge
what about oil psi and oil temp?
i'd think that a $20 Sunpro oil temp gaugee from autozone would be better than stock?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
