taillight tip - FirebirdV6.com/CamaroV6.com Message Board
taillight tip
  • taillight tip
    Hey friends....I may not be the inventor of this particular procedure, so if I am not...a thousand apologies. I thought it was a pretty good idea.
    If you have a cracked taillight on our generation 4 firebirds and camaros, there is the propensity for water to get into the light housing. This water will sit there and cause a myriad of problems. While changing a turn signal bulb last night on my 96 bird, I noticed water sloshing around in the fixture and figured that's what probably took out the bulb. So I went into the garage and got my cordless drill (if you use a corded electric, please be careful) and drilled four holes evenly spaced across the lenth of the bottom of the taillight assembly.(use a smaller bit) Needless to say, water came pouring out. Now, the fixture is clearing up...it was cloudy...and the water is gone. It isn't a permanent solution, but it sure helps till you can replace the problem taillight assembly. Hope this helps somebody out....blessings. [img]graemlins/wavey.gif[/img]
    \"this isn\'t flying...its falling...with style!\"<br /> -Buzz Lightyear<br /><br /><br /> 96 bright red firebird, T-tops, monsoon CD Flowmaster catback dual exhaust <br /><br /> <a href=\"http://members.cardomain.com/joyfellowship1\" target=\"_blank\">http://members.cardomain.com/joyfellowship1</a> <br /> <a href=\"http://www.joyfellowshipchurch.com\" target=\"_blank\">www.joyfellowshipchurch.com</a>
    Good advice..
    New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
      no youre not the first to do this when i worked at quick lube 2. we used to do that for customers with a heated up safty pin.
      help me build the ultimate sleeper soon ill have a lot more mods than i can list and watch out for the spikes. 02 firebird
        Kinda like slamming your thumb with a hammer, huh?
        If you get blood under your fingernail...you sterilize a needle...apply it to the nail and presto...it goes right through releasing the pressure....pretty neat.... ;)
          Pretty painful and smelly too...had to do it after dropping a fridge on my toe.
