Condesation on Exhaust Pipes? - FirebirdV6.com/CamaroV6.com Message Board
  • Condesation on Exhaust Pipes?
    I noticed in the mornings when it's colder outside than usual that my car will stutter a little when I give it a few revs, the RPMs will go up but then drop immediately back down to 1k. It usually does this for about 3 or 4 good revs then it idles/drives just fine. I also noticed a small amount of water trickle out of my exhaust pipes while I had it running in park. Is this just condensation from the change in weather or is this something I should be worried about?
    <a href=\"http://community.webshots.com/user/maniacls1\" target=\"_blank\"><b>2001 Firehawk #155 of 504 -M6</b></a><br />437 RWHP / 404 RWTQ -Dynojet (heads/cam)<br />12.34 @114 mph 1.7 60\' (bolt-ons only)<br />12.47 @116 mph 2.0 60\' (street tires, heads/cam)
    Nothing to worry about, I had the same thing happen to me. Actually it still does happen, a little water comes out and then it's gone, I think it's just from the temperature from night to day.
    1994 Camaro A4<br />Mods: Custom Intake
      Water is one of the by products from combustion. When conditions are right and the exhaust is cold, it will condense and show up as liquid dribbling from exhaust. Some vehicles show more of this than others it seems.
        <blockquote>quote:</font><hr>Originally posted by Backfire:
        Water is one of the by products from combustion. When conditions are right and the exhaust is cold, it will condense and show up as liquid dribbling from exhaust. Some vehicles show more of this than others it seems.<hr></blockquote>
        Actually, I believe that the catalytic converter turns the hydrocarbons into water (one of the products) and that is why water will spit out.
        2002 Camaro SS 6 Spd<br />Sebring Silver Metallic<br />Still breaking it in<p>Traded in - 2002 V6 5 Spd Camaro.<p>\"I\'ll never trust squirrels again.\"
          Agree with Backfire. Until the engine and cat reach operating temperature, you will see water in the exhaust pipes. At operating temperature the water is evaporated before it reaches the end of the exhaust system.
          2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
            Whenever you oxidize (burn) a hydrocarbon, the byproducts are carbon dioxide and water. But, when you burn a fuel under high pressure, other reactions are forced. Thus creating oxides of nitrogen and sulfur dioxides. That is where the converter comes in to break down the toxins. The converter creates a very high temperature setting that helps the catalyst break down the toxins and burning the rest of the fuel. There is always water vapor exiting the exhaust. Even on non-converter engines.
            1995 Firebird 3.8 A4, 140,000 miles and going strong<br />Basically Stock, college=poor <p>Junior Mechanical Engineering Student: Milwaukee School of Engineering; Cpl, MN Army National Guard...just got promoted :)
              C4H10 + 6.5 O2 = 4 CO2 + 5 H20
              (same for C5 and C6 and C7 and C8 and C9 etc.)
              Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
