PCV valve on 2000 firebird - FirebirdV6.com/CamaroV6.com Message Board
  • PCV valve on 2000 firebird
    I'm trying to locate the PCV valve... can anyone tell me where it is. It's not in the same place as the V8's?
    Re: PCV valve on 2000 firebird
    I'm pretty sure it's the same as my '97. On the intake manifold, there is a black plate with two screws on it. Remove them and the plate, and inside is the PCV valve.
    '99 Mountaineer AWD 5.0 - 4300K HID, Some Bolt-ons
    '97 RS - HPTuner, Bolt-ons
    '09 WRX - Aesthetic mods
      yes like logger said, it is on the top of your intake manifold under that black cover
      http://www.bowtiev6.com/
        see the 2 bolts next to the 3800. that is it. there is spring under there so becare when your taken it off.
        WAWA-A-HOLIC
          i read that if you shake it and it rattles then its good. i replaced mine anyway though.
            when you replace this what do you need to do? Just unscrew it pull it out, pop the new one in? do you need a gasket of some sort?
              Just unbolt it and put in the new one and bolt it back in.
                Ive read about guys loosing there gaskets or something though?
