You should be able to tap into the back of your radio for the 12 volt power wire using a quick splice, it's an orange wire from the factory wire harness. To get the wires from inside of the car to the engine compartment, there is a grommet behind your pcm on the passenger side of the car that you can slide some wires through. You have to move your pcm outta the way, then you can see the hole. Hope this helps.
1998 Arctic White Camaro<br />3.8L V6 M5<br />Flowmaster 80 Series with 3\" tips<br />Whisper Lid w/ K&N<br />Flowtech Cutout<br />Free-Ram Air Mod<br />Blue Underbody Neon Kit<br />3 MTX 6000 10\" Subs<br />Rockford 800a2 Amp<br /><a href=\"http://photos.yahoo.com/jeep327\" target=\"_blank\">My Camaro</a>
The orange wire you need to tap into should not be the one comming from the back of your cd player, you should use the orange wire that is part of the factory wiring harness that is not removable from the car...let me know if your still having problems.
Okay, Is it going to be were I can pull it out and work with it or In the back somewhere? All I see is 1 orange wire coming off a white connector that says illumination.
[ March 22, 2002: Message edited by: 97chevycamaro ]</p>
Dont call me chief.<br /><br />2001 Camaro Convertible Rs Replica<br />1991 Acura Legend
Ok, maybe GM changed wire colors between our years..Look at the manual for your aftermarket cd player. Find the page which tells you what each colored wire connects with. Look for the one that says "constant 12 volts". Then pull out your cd player and look at the wires directly comming from the player and tap into the correct wire according to the manual.
