ok i have a 95 firebird 3.4L, whin i start the car in the morening it runs realy rich this clears up. if the car sits and idles i will get a ses light but whin i drive it it will clear up. some times the ses light will come on whin driveing and the car will fall on its face after 3000 rpm's. i dont have a cat and have tryed to scan the ecm for codes but have had no luck. if eny of yall hav some ideas it would be great.
Help Pleas
Re: Help Pleas
ok i did finely get to run the scanner on the car and came out that the o2's were showing codes, so i replaced them and now the car is running fine. but now i have another Q what dus the code 82 mean?
and thanks for all the help guys
Re: Help Pleas
Originally posted by turbohead2332 View PostIf sounds a lot like my car. Listen for your fuel pump. Mine started doing things like that then the fuel pump went out. It will gradually run richer for longer times if that's the case.
