Horrible plug wear at 17,000 miles... WTF - FirebirdV6.com/CamaroV6.com Message Board
  • Horrible plug wear at 17,000 miles... WTF
    Well i got around to changing my factory plugs last night in preperations for my charger going on and i was shocked to say the least at what the plugs looked like. These are supposed to be the factory 100,000 mile plugs and they are completely trashed... To date i have no mods on my car other than gears... Check out the pics
    Plug Picture 1. You can see the electrode transfer onto the arm.
    Closer view of the plugs...
    As you can see all six plugs where the same way.
    2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
    Your plugs are fine. They are designed that way. There is an electrode on the arm so that they last longer. Whenever the plug fires it loses some metal from the arm where the spark jumps. They found that the electode metal doesn't lose as much than the arm. Dissimilar metals. They weld a new electrode to the other side. Same metal as the the inner electrode. This way they last longer and don't lose as much metal. That's about the easiest that I can explain it.
    2000 Silver Firebird<br />1988 Maroon GTA
      <blockquote>quote:</font><hr>Originally posted by Scott T:
      Your plugs are fine. They are designed that way. There is an electrode on the arm so that they last longer. Whenever the plug fires it loses some metal from the arm where the spark jumps. They found that the electode metal doesn't lose as much than the arm. Dissimilar metals. They weld a new electrode to the other side. Same metal as the the inner electrode. This way they last longer and don't lose as much metal. That's about the easiest that I can explain it.<hr></blockquote>
      Interesting, didnt realize although it makes great sense... Even still it was startling to see that when i pulled those out i was like what the hell....
        well if that scares you, pull your new ones in about 3k miles.. they will look about the same.. :D
        -Brad
        2000 V-Star Custom 1100
        :rock:
          <blockquote>quote:</font><hr>Originally posted by black98V6:
          well if that scares you, pull your new ones in about 3k miles.. they will look about the same.. :D <hr></blockquote>
          Hopefully not with my new TR6's [img]smile.gif[/img]
