Where can I find these for a 3.4L? I have alot of lean in my driveline and figured those along with a poly-tranny would correct most of it. How bad would the install be too? Thanks.
Poly motor mounts...
The poly-tranny mount is easy, the only thing I recommend would be have something other than a hacksaw to make the hole in the cross-member longer. Took me about an hour even with messing around with the hacksaw...Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Looks like you'll have to disconnect the exhaust crossover pipe, then the engine mount through-bolts/screws and nuts, jack up the engine, more screws/bolts and then the mount assemblies.Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
ive never seen a polyuerathane motor mount for our cars, however if you were to find one let me know [img]smile.gif[/img]
also it wouldnt be harder than replacing the mounts with other stock units, you would have to detach the current mounts, and support the motor in some other way, and bolt the new mounts in place-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
Heya Studly, if I remember right you have something to do with 60Degv6.com, right? You remember wanting to get an M90 from anyone there in exchange for some heads and a throttle body? If so, that was me... if not, ignore me, lolCheck out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
There are not any poly mounts available for our engines. Your only hope would be to get some one to custom make some engine brackets for you.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
