How hard would it be to change the rear main seal on a 93 camaro? Anyone ever done it/ have any advice?
Rear Main Seal
Re: Rear Main Seal
i think kristen did it. i dont think its hard, just time consuming. I have also heard of ppl replacing it and it still leaking. how bad is the leak ? mine as a drip every now and then1997 Camaro LS1 RS
1994 Camaro - Sold
1999 Trans am Vert - Sold
A Few Mods....
Re: Rear Main Seal
you will have to remove your flywheel. It can be done but is a pain if doing it in a driveway. If you have a lift it is easier.
Mine has dripped a bit since the day I got it when it had 77k on it. Now over 105k and never changed it
Re: Rear Main Seal
I've wondered the same thing...I know its like 600$ to get a shop to do it...would mods help to make something like this worse?
Re: Rear Main Seal
Originally posted by LETZRIDE View PostI've wondered the same thing...I know its like 600$ to get a shop to do it...would mods help to make something like this worse?
Re: Rear Main Seal
Originally posted by 97rs4life View Postmods? no they have nothing to do with this.
Re: Rear Main Seal
Originally posted by kristen View Postthe only reason i did mine was because i was replacing my clutch. the oil pan is my pita lol
you would have to drop your transmission, if your a manual you would have to remove your clutch and flywheel. then becareful getting the old one out. not to strach the plate.
Re: Rear Main Seal
ok thanx guys. btw its an auto.
what about lucas transmission treatment, it says it would stop most leaks....anyone have any experience with that?
o and one last thing..."technically" if i just slowly keep adding tranny fluid, that just like a small oil leak, it wont affect performance right? as in my tranny isnt going to seize or break right?
Re: Rear Main Seal
Not sure how different a 93 is,.,.I have a manual 99 and while I was at it, I've changed the clutch since I was dropping the transmission. IIRC, I jacked up the car(of course) then I pulled out the driveshaft, drop the tranny on the floor jack. Changed the clutch, took the old seal out. When I took out the seal, all the coolant came out along with oil. The hardest part is scraping the remaining seal off. Cost about ~300 bucks for all the clutch parts and seal. Seal was way cheap as I recall, I think ~$5. There was a line going into my transmission that requires a special tool to disconnect.
Good luck =)1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
Re: Rear Main Seal
you have an even bigger problem if your rear main seal is leaking transmission fluid.
but in any case, DO NOT use those lucas crap products, when used with "gears" they cause small bubbles which can ruin your oil pump/transmission/differential gears.
if you dont believe me, go find one of those little displays at the part store and spin it really fast compared to the other oil, you will see millions of bubbles in it
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
