All things that can cause bad gas mileage - FirebirdV6.com/CamaroV6.com Message Board
  • All things that can cause bad gas mileage
    I want to make a list of ALL things that could cause a drop in gas mileage.
    1. Under-inflated tires.
    2. Bad oxygen sensors.
    3. Bad EGR valve
    4. Clogged catalytic converter
    5. Bad PCV valve
    6. Extra weight (sound systems, etc)
    7. Carbon buildup in intake.
    8. Dirty fuel filter
    9. Old oil
    10. Dirty injectors
    11. Old plugs/wires
    12. Dirty air filter
    13. Bad gas cap/leak (evaporation)
    14. Bad spark plugs
    15. Bad air temp sensor
    Anything else?
    2001 Firebird 3.8L
    Re: All things that can cause bad gas mileage
    leaking fuel injectors, evaporation if your tank isnt sealed or bad gas cap. dirty spark plugs, and bad air temp sensor; just off the top of my head.
      -unecessary crap like sound systems
      -Bodykits
      -Carbon buildup in intake.
      -dirty fuel filter
      -old oil
      -dirty injectors
      -old plugs/wires
      -dirty air filter
        Too many cylinders ;)
          Originally posted by ViperRider View Post
          I want to know ALL things that could cause a drop in gas mileage.
          3. Bad EGR valve
          5. Bad PCV valve
          Anything else?
          6. You
            Originally posted by Smoke Panther View Post
            6. You
            I don't see how, I only weigh about 190 and keep the revs below 2500 rpms. And I get 18 MPG city. But yea a lead foot driver could cause bad gas mileage, but I'm not talking about that though, only things ON the car that can cause bad MPG. Thanks for the input though. :tup:
            2001 Firebird 3.8L
              Bad oxygen sensors and Bad EGR valve what if u dont a sens light on these will they still go bad i thought if they do u trigger a code
              2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
                good question, wondering the same thing...
                  anyone?
                    Yes, it will affect even if not sending a light. think of it this way, if it does read a lean or fich mixture and such, when new, it will correct it exactly to what it needs to be, but when old, and with carbon and exhaust gasses covering the probe, it wont react as quickly, and wont give as precise an exact amount that you need, so most likely it will dump more fuel in, especially if it reads lean when actually your mixture is fine. The only time it comes on is when the sensor is faulting (going bad) not reading anything, or reading that your mixture is way off for a period of time ( say like 30 second). Unless the mixture is waaayyy off, either lean or rich for an amount of time, it wont send the light on. It can become way off for a split second ( idle to WOT) but our cars amount of air and fuel we get, is pretty precise as it is with the other sensors like IAT, MAF,etc. so the oxygen sensor usually doesnt read way off mitxures for a period of time, but when it does, you will get a light. So yes change your oxygen sensors for a more precise reading.
                      cool thanks for the info but what about the egr?
                        Agressive driving.... lol
                        1998 Red T-top V6 Camaro
                        - K&N Filter, Pacesetter Headders, MagnaFlow 2.5" Hi-Flo Cat, FlowMaster 80 Series, PowerDyne Supercharger@9Psi More 2 Come
                          I weigh 180. I try to keep it below 2000. Do think I should step it up to 2500?
                          Also, getting a big Trans Am wing, decreases fuel efficiency.
                            I didn't think the EGR would cause a noticeable change in mileage. Some people just remove them without any adverse effects.
                            Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
                              Slipping Tranny creates excess power from engine that never sees the rear wheels...
                              Y87 Package
                              MANUAL CONVERTED, Pro 5.0 Shifter
                              Pacesetters, Magnaflow Cat, Cutout, Flowmaster
                              MOGOB APPROVED!
                              BONE APPROVED!
                              VANBIBBER APPROVED!
                              KRISTEN APPROVED!
                              Vice Prez.
                              Team Black...TEAM EMO
                              Come on kids! Get a Calendar!
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
