Spark Plug Problems I Need Help Please - FirebirdV6.com/CamaroV6.com Message Board
  • Spark Plug Problems I Need Help Please
    Hi Guys Thanks For Read Mi Problem
    I Have A 1995 Camaro 3.4 One Of The Sparplug Got Black The Another 5 Its Ok I Have To Change Mi Spark Plug Every 2 Or 3 Monts Because Of That Any Idea Way?
    I Have Problem Before Whit The Coil I Replace The Coil,i Repalce Whires Also Replace Catalytconvert ,
    On Mi Car I Have Stage One Air System And Catback Magnaflox Mufler Also I Have Electric Supercharge (no Big Deal Buy In Ebay)
    But The Sparck Got Black I Check In The Book Of The Camaro Say Someting Like Too Mucht Rich Air Mix Whit Fuel ,i Reali Don't Know Way Happening In Only One Sparckplug
    Any Help Whit Be Good For Me
    Thanks
    Jay
    Re: Spark Plug Problems I Need Help Please
    for one thing, please dont type in all caps
    next, i am having a hard time understanding what the hell you are trying to say, but it sounds like that cylinder is running rich, or you have an oil leak
    can you take a picture of the spark plug?
    is the cylinder firing?
    is the plug wet, or dry?
    did you test to see if the new plug you put in is firing correctly?
      sorry for the caps yes the cylinder look like is running rich ,i don't have any oil leak
      and the cylinder firing ok because when i take te whire from the coil i see spark nice blue spark
      and the plug is dry
      i fell the dirferent when i replace the plug but afther couple months is smoke black again
      im sorry i troe the plug to the trash i don't have a pic
      last time i use ngk v-power
      now i use oem resistor
        You probably have a bad injector on that cylinder leaking gas into the engine.
          im betting on a bad injector
            Sounds like a bad injector
            Y87 Package
            MOGOB APPROVED!
            BONE APPROVED!
            VANBIBBER APPROVED!
            KRISTEN APPROVED!
            Vice Prez.
            Team Black...TEAM EMO
            Come on kids! Get a Calendar!
              thanks everyone for your help i will try to replace the injector this weekend
              thanks again
