Coil bolt - FirebirdV6.com/CamaroV6.com Message Board
Coil bolt
  • Coil bolt
    changed my coils yesterday in the tightest space ever, dropped a bolt. Anybody know what size bolt that is?
    P.S.
    98 3.8
    Re: Coil bolt
    Take one of the other bolts, go to the hardware store, and use guide.
    Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
      Re: Coil bolt
      well, you are prolly going to have difficulties gettin one from a hardware store. the bolt is an unusual size. I would recommend gettin to a junk yard.. take one with you to match it up. not certain, but i would image a lot of GM cars use similar bolts, since a lot of their cars used those same coil packs.
      i found a 1/4" drive ratchet with the 5.5mm deep socket works wonders on gettin those things out.. if you dont have that socket, pick up one from autozone.. one of the best tools ive aquired...
        Re: Coil bolt
        yea i found out it is an unusal bolt when dropped the socket in the engine bay and tried to buy another one
          Re: Coil bolt
          I have got many of my bolts, nuts and screws form ACE Hardware, pretty much have anything as long as you have a bolt or know the measurements. Also Home Depot/Lowes.
