Okay first off there isnt any coolant leaking inside the car from the heater core. I was wondering do we have like heater fuses for our cars and maybe a fuse is blown. The problem is the car ac blows very cold and when I turn on the heat the air is still cold. I have already changed the thermostat so I don't know what to do. In the morning my side windows are very foggy and my cars temp is around 235 or 240 I just can't figure out my cars diagnosis can someone help me out.
How do I flush my heater core hoses with the heater core still on maybe its something stuck in the hoses
what may have happened is that air got into your lines. start up your car and let it build some pressure. there should be a screw near the thermostat. open it up with a flathead and let the air get out. keep doing it until you dont see air comming out of it. there should be water comming out of the bleed screw.
Take off the glove box and make sure the doors move when you change temp setting. If not then the warm air from the heater core is not redirected into the cabin.
well I just got the problem fixed turned out that I had a water pump leak so there was no water running to my engine my mechanic changed out the waterpump for a brand new one with 1 year warranty and now the ac blows hot and cold air. I am so happy now
Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...
