On the way to replace the intake gasket - FirebirdV6.com/CamaroV6.com Message Board
  • On the way to replace the intake gasket
    Today it miss 1/2liter of coolant in my bottle so to avoid damage to my engine i will replace the intake gasket soon.
    As i live in France i will buy my parts on rockauto. so i need:
    - Intake Manifold Gasket
    FEL-PRO Part # MS958091
    2nd Design; w/Rubber-plastic end seals w/Locating pins; Lower set
    -Fuel/Air : Plenum Gasket Set
    FEL-PRO Part # MS95746
    RWD; Upper set
    -Fuel/Air : Fuel Rail O-Ring Kit
    STANDARD MOTOR PRODUCTS Part # SK26 {INLET/OUTLET O-RING KIT}
    INLET
    I need also the two plastic elbows but i don't find these on rockauto, what the exact term?
    Does the parts are good?
    Does i will need other part?
    Thanks for your help
    Re: On the way to replace the intake gasket
    I couldn't find them on RockAuto either when I needed them, I ended up just buying them from zzp.
    Last edited by 99pewterv6; 03-03-2008, 02:06 PM. Reason: I saw you lived in france no parts for you car locally
    Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
      Yes the rockauto guy tell me he don't sell it. I don't know how i could find them. In france it will be very expensive.
      I have check my oil cap. There is a few water on it but clear. Not the coolant color. What's the hell.
      Thx
        Do you recommand fel-pro?
        For the plastic elbow do you know an other shop who can send them to france?
        Thx
