vibration - FirebirdV6.com/CamaroV6.com Message Board
vibration
  • vibration
    when the car is stopped at a light, it vibrates like crazy, the dashboard especially and when i shift into neutral the car smoothes right out. anybody have any ideas? its a 94 camaro, 3.4.
    thanks
    Re: vibration
    Do you have your AC on?
      Re: vibration
      He is stopped at a light if the clutch was engaged he would be stalled out or rolling through the light.
        Re: vibration
        it's an automatic trans
          Re: vibration
          TCC Solenoid may be stuck in the "on" position, so the converter might stay locked up too long. That'd cause a hell of a vibration. Do you notice any Engine Speed drops? Does the condition happen after anything specific? Highway driving or driving at speeds above 55 mph perhaps? 94 was the first year for the 4L60E, and I know that I had the TCC problem with my 96.
          Y87 Package
          MANUAL CONVERTED, Pro 5.0 Shifter
          Pacesetters, Magnaflow Cat, Cutout, Flowmaster
          MOGOB APPROVED!
          BONE APPROVED!
          VANBIBBER APPROVED!
          KRISTEN APPROVED!
          Vice Prez.
          Team Black...TEAM EMO
          Come on kids! Get a Calendar!
            Re: vibration
            except for the vibration the car runs good. the idle is steady about 700-800 rpms with the vibratiuon but when i put it in neutral i'll pick up to around 900 rpms and the vibration goes away. it only occurs when the car is stopped.
              Re: vibration
              mine does that off and on also... i figure its indigenous to the 3.4s because i know of someone elses that does it pretty bad too
                Re: vibration
                Try cleaning the injectors.
                  Re: vibration
                  That one is true, when I rewired my M5 to a A4 I didn't get the pin connector all the way in on the pcm, it would vibrate like hell in Drive and fine in neutral, the wire was the TCC control to unlock and lock the converter, should throw a code , my wire was a brown wire on the pcm I think it the was 55 pin.
                    Re: vibration
                    My dad's Honda does the same thing. He says it's the mounts (motor and trans). Might want to check them out, IDK.
                    ~97 3.8L V6 Camaro~
                    A few things
                    Only Member of Team Hooker?!?
                      Re: vibration
                      it doesent show any codes
                        Re: vibration
                        i suspect it could be the motor mounts. i already replaced the trans mount and it didnt make a difference. how do you check the motor mounts, and if they have to be replaced , is it a hard job.
                          Re: vibration
                          A valid point.
                          Looks like there's a long checklist!
                          Y87 Package
                          MOGOB APPROVED!
                          BONE APPROVED!
                          VANBIBBER APPROVED!
                          KRISTEN APPROVED!
                          Vice Prez.
                            Re: vibration
                            mine does the same thing
                            try this thread
                            http://forum.camarov6.com/showthread...ght=rough+idle
                              Re: vibration
                              has anyone replaced motor mounts on a 3.4 before, if so how difficult is it'
