I had my car going 2 weeks ago after being stored all winter and it started fine. I had to put new valve cover gaskets on and re set my rockers. Tried starting it over the weekend and only clicks. Won't roll over. I checked all the grounds, battery, firing order. I wonder what else could it be?
Car won't start? Just clicking
Check the connections on the starter. I had two different cars with the same problem. It acted like a weak battery. After checking the battery and even trying to jump the battery I found the problem. It was the large cable on the starter. It was lose. You will have to get under the car to check it.
Hope it helpsDr Todd
Sounds like a poor electical connection somewhere.
-Check Battery
-Check battery connections for tightness
-Check battery posts for corrosion buildup
(sometimes corrosion buildup can occur on the
cables themselves hidden by the cable insulation)
-Check all fuses ... in dash and under hood.
-Check starter connection
If all of that checks out as good then you may have a problem with your ignition shwitch or something could be wrong with the anti-theft stuff (maybe your key is fouled).
If all of those things are in OK then it should at least turn over.
is it a 9696 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
