Help Please!!! - FirebirdV6.com/CamaroV6.com Message Board
Help Please!!!
  • Help Please!!!
    Ok yesterday Long isnad had a huge rian storm. I drove threw a pretty big puddle. Right as i got out of the puddle my car stalled. Now when i Try to start it there is just a loud clicking. And somtimes it sounds like the engine turns over for a sec. What could it be???? the starter motor???
    HELLLLPPP
    ....WHITE CAMARO CLUB....? =(
    Re: Help Please!!!
    Water may have entered your intake. Depending on the depth of the water.
      Re: Help Please!!!
      never drive through high water...especially with a low car like an F-body :(
      id say too much water go in the intake also. as for ways to fix it? i dont know...
      1999 Firebird Y87/W68
        Re: Help Please!!!
        I dont think it was high enough to get into intake.
          Re: Help Please!!!
          Water may have drenched something electrical? Just a suggestion.
          Originally posted by LETZRIDE
          I've never touched a rear end before
            Re: Help Please!!!
            Water could have gotten to the starter. Also check your battery.
            Better check for water just in case. Take out the air intake tube and check for water. Check the air filter for water. If you find it damp, then what I would do, and what i have done when a friend drove his car through water, is clean out the area around the spark plugs and take out the spark plugs (yes, all of them). Inspect them for water (this is a good time to clean them and gap them). Squirt a little bit of engine oil down in the cylinders and try to get the engine to turn over. If it's not turning over, make sure the battery connections are tight and you have a good, charged battery. The engine should crank over and you should see water flying out. it may help to take a rag and place it over the spark plug hole as the engine is turning over.
            If you have water in the pistons, change your oil. after being as sure as you can that all the pistons have the water out of them (turkey basters and a short piece of tubing are great for this among other things...), put the spark plugs back in and reassemble the dry air intake. Start her up and get it warmed up to evaporate any water that may be left in the crank case.
              Re: Help Please!!!
              you probally hydrolocked it pull the spark plugs and crank the motor se if water pumps out
                Re: Help Please!!!
                I reall appreciate the help guys. I will be doing this all tommorw. Thanks again.. i really appreiciate it.
                  Re: Help Please!!!
                  so the car hasnt started since you drove thorugh the puddle?
                  immediately it stalled?
                  its either computer (electrical) or you sucked up water, which i kinda doubt, but anything is possible.
                  if you hydrolocked your engine, you are looking at a ton of money, because an engine going from 2000rpm to 0 aint gonna be a walk in the park
                    Re: Help Please!!!
                    ****. How much you think.??? i hope its not serious.
                      Re: Help Please!!!
                      Like it turns over for a second. After it clicks really loud.;
                        Re: Help Please!!!
                        you definatley have an electrical problem. check starter. lets the car dry out for a while. depending on the puddle you could have water anywhere
                          Re: Help Please!!!
                          Agreed sounds electrical but I still would want to know that there's not water fouling the plugs. Find out where the water is and isn't. Is the air filter wet?
                            Re: Help Please!!!
                            Ok. today i looked in intake. There was water. I took all plugs off, and banged on the starter motor. I finally got it to turn over, It seems ok. Im gonna buy new oil oil filter and new plugs before i get her going again. The plugs were wet,
                              Re: Help Please!!!
                              you will want to change the oil more than once.
