this all happened about 15 minutes ago. and keep in mind i just installed a powerdyne S/C on my car. ok so i floored the car, and once it got to the top of the RPM's it cut out while still running, i got the "reduced engine power" light, and pressing the gas pedal did nothing at all, there was absolutely 0 throttle response. i had to idle into someones driveway. i popped the hood to check if anything obvious happened like vacuum tube blew off or the tensioner gave out and the belt was flopping around. everything looked fine, so then i went back to my car and fired it up, and everything worked like normal.
this is really weird and ive never heard anything like this happening. you think the PCM "paniced" or something and shut down? scary :(
