Below 40. Your delayed throttle could be because of a code being set. If the idle settles out after a minute or so, it to could be from a code as well. Some codes put the PCM in "limp home " mode, so you can drive home with the problem.
interesting. thanks a lot you guys. ill get her scanned tomorrow and post up what ive found. ill also quadruple check (seems like im pushing and checking on vacuum lines in vain...) vacuum lines again.
i mean right at start up. like you know when you fire the car up it revs up a little bit then settles down to normal idle speeds. well mine flies up to 2k before settling down. see what im saying? if not you'll see when you start your car up tomorrow.
nonono...very very beginning as soon as you fire it up. it has never done this before and does it every time, even when warm. im not saying it stays there and idles at 2k. as soon as i fire the car up it revs up to 2k, then floats its way back down to 800ish 900ish at idle. it used to only go up to 1300 or so then back down to normal idle speeds. im talking about the first 2 seconds of the engine being on.
This may not help, but I found this guy on youtube and thought that maybe he might be able to help you out. Who knows, maybe he is a member on here and you are allready in touch with him, but here it is anyways. http://youtube.com/user/redmaro42
yeah. so i wont be able to scan till the weekend. the guy i knew with the scanner forgot it back home, as we are away at college now. hes having it shipped here though so itll be here by the weekend. by then ill have a tune though haha
wow thats funny, EXACT same thing that happened to my car as my bro mentioned, I was having some fun doing spirited driving and all a sudden WHAM car died and i slowly crept into a nearby apartment complex, started it up and it was fine babying it on the way home, my bro thought he had the tune fixed but it did it again, as of the end of fall before putting it in storage it was perfect :)
haha yeah, it was pretty scary. well im getting the car professionally tuned this weekend and am buying HPtuners over the summer, but hopefully after this weekend the car will be 100%
