okay, so my drivers side won't hit the window, i can't get it to get enough pressure. have changed both wipers, and tried pushing the arms down hard as possible. top part makes a little connection, but bottom part nothing. its a 96, any ideas?
Windshield wipers
Re: Windshield wipers
What I've found is that the "J" hook for the wiper arm is, in effect backwards, causing you to have to put the hook through the wiper blade before locking it in. Because you do that, the arm contacts the frame of the blade. What I've done is mark where the frame of the blade hits the arm and remove that section. The blade should be able to pivot and will work.
Originally posted by Flurgen View Postto me i get it on fine with no problems, its just the arm is not applying enough pressure to get the wiper to work
Its the spring like Josh said. had the same problem a couple times. I got replacements from AutoZone and they only lasted 6 months before having the same problem. I finally dropped the change to get the wiper arms from the dealer and haven't had a problem since.Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
I had the same problem and replaced blades and still didn't work. I went to dealer to order new arms and the guy said I didn't need them and described the following quote that I didn't understand then and still don't.
Originally posted by steddy View PostWhat I've found is that the "J" hook for the wiper arm is, in effect backwards, causing you to have to put the hook through the wiper blade before locking it in. Because you do that, the arm contacts the frame of the blade. What I've done is mark where the frame of the blade hits the arm and remove that section. The blade should be able to pivot and will work.
He went out and installed blades and no change after a few minutes he messed with them and they were working again. Now its that way again but if I push down on them as there moving before I go on my commute they work for the trip. I wanted to look at them this past weekend but was unable so I plan on looking at them next weekend.Originally posted by kalaI'll have buttsecks with Richard Simmons!
TEAM BLACK!!!
parting her out
Originally posted by crushedout View PostI went to autozone and they didn't have them in stock, it was special order he said
Originally posted by jnxV6 View PostThat is weird, I know Advance carries Tricos and the number is 24-9R for the 93=97 Camaro and Firebird. In the computer that is the only wiper blade that comes up for those cars.
well it may be because it was a smaller autozone in a small townOriginally posted by kalaI'll have buttsecks with Richard Simmons!
TEAM BLACK!!!
parting her out
