My Firebird's alarm system will not make a sound when I set it off. The lights flash and thats it. I was told by the dealer that it was very sensitive and it was annoying and it worked just fine. But not anymore something has changed since i have owned it. Anyone else have this problem?
Alarm system sound
If you have an aftermarket, check and see if the ground wire coming from the alarm is conected. Every time I disconnect my battery to work on my car I take the ground wire off so that when I connect my battery again my alarm dosent send through my hood. Just the lights flash.
Thanks i'll check into thatHeady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
