ses light - FirebirdV6.com/CamaroV6.com Message Board
ses light
  • ses light
    I was driving my car and the ses light came on, so i drove to autozone and I has them scan it, the code is po1o3 can anyone tell me what that code means, thanks.
    cold air intake <br />80 series flowmaster<br />no cat (straight pipe)<br />rebel flag
    mass air flow sensor circuit, high input
    1999 Firebird
      whats that mean bad sensor? or do i just need to cean it and how
        I'm not positive but I think it has to be replaced.
        1999 Firebird
          Doesn't automatically mean the MAF sensor has to be replaced. There are other things that could be the cause, but yes...the most common reason for this is a bad MAF sensor.
          Matt
          1998 Mystic Teal Camaro M5
            y what should i expect from my car preformance if the maf is bad or going bad
              You need the MAF so the PCM can measure the airflow going into the engine. If there's something wrong with it, the sensor could be sending back false results.
              Matt
                ok i unplugged the battery to restet the code i turned the car on the ses light was off, until right after i unplugged the maf sp does this mean its ok, because the car doesnt run or idol any different. what i was wanting to know is if a maf has gone bad what will the car run like so ill know. thanks for all your help
                  It could make the engine run rich.
                  1999 Firebird
                    rich engine could blow it out from your hood so be careful
                    3.73 gears ramair kit flowmaster is no more now BORLA cat-back 3\"catco cat<br />best et w/ flowmaster 14.8 best et w/ open borla 14.62@94mph :)best et w/ open borla and drag radials 14.4 at 96 o yea and a set of pacesetters
                      Sometime a small electical hiccup or other anomaly can cause a sensor to throw a bad code. The first thing to do (which you did) is clear the code. A scanner works best, unhooking the battery for five minutes works well, too. If the code does not return, you should be fine. If it does return, it was not a hiccup and you should get it fixed for reasons already mentioned.
