Stupid Question - Y87? - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • Stupid Question - Y87?
    Alright, I hate starting useless threads, but I've been looking for an answer to this for the past couple of days.
    Before coming to this board, I had no idea there was a Y87 performance package. My question would be how do you tell whether or not you have the package? I've got disc brakes all around, and she leaves nice two-wheel burnouts, but other than that I don't know how to tell.
    Also, I'm Anthony, and I'm from the Danbury (CT) / Poughkeepsie (NY) area. I drive a Hunter Green 96 Camaro, and this board freaking owns. If there's anyone out there in my area, hit me up.
    [ January 18, 2004: Message edited by: fre ]
    [ January 19, 2004: Message edited by: fre ]</p>
    1996 Hunter Green Chevrolet Camaro A4 Y87 - 3.8 Series II V6 (200k and still going strong)<br />Flowmaster 80 Series Muffler, SLP Cold Air Intake
    Check your RPO codes, either on your door or in your glovebox. If you see Y87 listed, you've got it. If it's not there, then you don't have it. ;)
    Matt
    1998 Mystic Teal Camaro M5
      You should have the RPO code on the Service label in the glove box, as ONLY Y87 V6 cars had disc brakes in the rear in 96.
      Raven
        <blockquote>quote:</font><hr>Originally posted by 98Camaro3.8:
        Check your RPO codes, either on your door or in your glovebox. If you see Y87 listed, you've got it. If it's not there, then you don't have it. ;) <hr></blockquote>
        <blockquote>quote:</font><hr>Originally posted by FirebirdGT:
        You should have the RPO code on the Service label in the glove box, as ONLY Y87 V6 cars had disc brakes in the rear in 96. <hr></blockquote>
        Easy enough, I checked, and much to my delight, it does have the Y87 package. I guess this means I don't have to invest in gears / posi right now. Thanks!
        :D
          nope.. LUCK YOU!! [img]graemlins/crybaby.gif[/img]
          96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
            What all comes with the y87 package? When did they start it 2000 and up 3.8's? Do you get a higher gear? Limited slip differencial? Dual outlet exhaust... What all do you get with the y87 package?
            Thanks, Shane
            <a href=\"http://www.f150online.com/galleries/mygallery.cfm?gnum=2352\" target=\"_blank\">2000 Lightning</a> <br />Chip, Filter, Pulley<br />12.64
              <blockquote>quote:</font><hr>Originally posted by Shane McKenna:
              Thanks, Shane
              <hr></blockquote>
              It is all in the Technical Database.
              Raven
                I'll save you the time of digging through...
                in a nut shell for automatics...
                upgrade from 3.08 to 3.42 gears and added a LSD
                Those are RPO codes GU6 and G80 if you wanna dbl check to see if you got those.
                For the manual it's still 3.23s but you get an LSD.
                THe only other important thing is you get the Z28 sterring ratio (less turns of the wheel)...it's 14.4:1 if I remember right.
                Oh yea and 235 tires and a dual outlet muffler :rolleyes:
                :D
                  <blockquote>quote:</font><hr>Originally posted by I H8T3 R1C3:
                  :D
                  <hr></blockquote>
                  Not complete, YOU should go read the Technical Database.
                  Raven
                    <hr></blockquote>
                    that's the most important part of it...you wanna challenge me on what I know go ahead. You'd be surprised.
                    There are a few flaws in your database FYI
                    [ January 24, 2004: Message edited by: I H8T3 R1C3 ]</p>
                      <hr></blockquote>
                      I do challenge you. Next time maybe you should read a persons bio before replying.
                      And if you THINK there are flaws in the Tech Database - email me.
                      Raven
