Mod list - FirebirdV6.com/CamaroV6.com Message Board
Mod list
  • Mod list
    Ok, now that I've done my cat-back i think i've been bit by the 'mod bug' ;) . So i'm trying to think of what i can do next. I'm planning on getting a 2.5" in/out high flow cat, rksport headers, but after that i'm stuck :( . What else is there to do w/ a 3.4L I would really rather not mess with the engine itself.
    Anyone with ideas? If you suggest something please go into a little detail (why, how hard, etc.)
    thanks [img]graemlins/burnout.gif[/img]
    RedlineVSix
    naaaaaaaaaaawsssssssssss
      try underdrive pulleys, they free up some hp and let you rev a little quicker. Take care of all the intake stuff such as the free mods that are listed as well as filter, cold air intake, ect. That will get you hp/tq and throttle response.
      2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
        anyone else?
        RedlineVSix
          Cold air intake: Moroso, K&N, or SLP $200
          underdrive pulleys: ASP $80
          ignition: MSD DIS-4 $320
          shifter: B&M or Hurst $170
          These are all basic mods which are easy to install and afordable.
          Some easy suspension mods are:
          bigger sway bars with poly bushings and endlinks $200
          SLP T/O springs $50
          SLP T/O shocks $50
          RED 1995 CAMARO 3.4L<br />Moroso cai, ASP Underdrive Pulleys, B&M Shifter, Flowmaster 80-Series Muffler, Polygraphite Sway Bar Bushings, Endlinks, and Panhard Rod Bushings
            <blockquote>quote:</font><hr>Originally posted by srogersilkl:
            SLP T/O springs $50
            SLP T/O shocks $50
            <hr></blockquote>
            What is this?
            <a href=\"http://alternatebw.homestead.com/files/cam19.JPG\" target=\"_blank\">1996 Camaro 3800II Y87 A4</a> (SOLD)<p>NEW CAR:<br />2003 Ford Mustang
              They are the springs and shocks Street Legal Performance takes off the trans ams and Z28's when they convert them into Firehawks and SS's.
              1995 Camaro 3.4 v6. Dead<br />1995 Trans Am FIPK.
                Ok, here's what i'm looking at so far...
                in no paticular order:
                1. rksport headers
                2. high flow cat 2.5" in/out
                3. Jetchip
                4. N2O (got some questions about this one ;) )
                5. gears
                6. torque converter
                7. LSD
                ok, what order do you guys think i should go in? (this stuff is going to be done as money is available) what brands do you guys suggest? any particular place to buy from? what can i install w/ some help and what do i need done for me?
                as far as nitrous goes, what size shot can a 3.4L handle? wet/dry? what kit?
                thanks guys
                RedlineVSix
                  <blockquote>quote:</font><hr>Originally posted by 95fbirdkid:
                  1. rksport headers
                  3. Jetchip
                  5. gears
                  6. torque converter
                  7. LSD
                  thanks guys
                  <hr></blockquote>
                  well if it were me
                  1. CAI
                  2. gears/Posi
                  3. shift kit
                  4. headers/cat
                  5. NX kit
                  6. Converter
                  <a href=\"http://www.velocitysix.com/\" target=\"_blank\">Velocity Six Car Club</a><p>1999 Pontiac Firebird A4<br />15.384@87.13mph
                    He's already got a cold air induction, look at the sig.
                    But here's the order I would recommend you take (out of the items you listed):
                    1. High flow cat (Catco from SummitRacing.com - $50)
                    2. gears & LSD (swap in a Z28 rear and get both at the same time, as well as rear disc brakes - something like $350 I think, can be found at SpeedAutomotive.com)
                    3. JET chip
                    4. torque converter
                    5. headers (you may look into Pacesetter headers also)
                    6. Nitrous
                    Other goods to consider:
                    -Shift kit (TransGo) since you have an automatic
                    -Aluminum driveshaft (can get a used one from SpeedAutomotive.com for about $175 I think or buy new from GMPartsDirect.com)
                    -Strut tower brace (BMR has good ones for about $85)
                    -Subframe connectors (check out BMR)
                    [ March 24, 2002: Message edited by: RacerJ ]</p>
                    -James<br /><br />\'96 3.8L A4 Camaro (SOLD)
                      i installed a posi myself, it only cost about 100 bucks. If i could do it over i would have swapped a z28 rearend. It still is the best money I have ever spent on my car, its worht it. If you want to go with n20 i suggets a NOS dry kit 85 shot. if my current ZEX kit deals falls through I'll let you know. rksport headers leak, screw 'em. Just get pacesetters, i wish they made them for the 3.8l. If you want more n20 info, do a search in the forum.
                      Josh<br />96 Red Firebird <br />SLP intake, zex nitrous 75 shot(for sale), purge kit, MAC lca + phr, Jamex springs, flowmaster 80 series, ES tranny bushing, SCR subframe conectors, Harlan shiftlight, A/F guage, MSD dis-4, Accel wires w/ NGK tr6\'s, foglights, stereo, zexel torsion LSD, Walboro 255 pump, and more.<br />Looking for: 1le ds, nx wet kit + accesories
                        <blockquote>quote:</font><hr> Originally posted by RacerJ:
                        gears & LSD (swap in a Z28 rear and get both at the same time, as well as rear disc brakes - something like $350 I think, can be found at SpeedAutomotive.com)<hr></blockquote>
                        One of a T/A or formula would work too right? I'd kind of like to stay w/ the same type of car. Can i install this or will i have to have it done?
                        <blockquote>quote:</font><hr> Originally posted by Josh:
                        rksport headers leak, screw 'em. Just get pacesetters<hr></blockquote>
                        In the Modification review on this board it says that the 3.4L headers don't have a prob. leaking is that [img]graemlins/bs.gif[/img] ?? Where can i get the pacesetters? which costs more?
                        also w/ a torque converter what brands and stuff should i look at.. anyone have one on their 3.4?
                        RedlineVSix
                          ttt
                          RedlineVSix
                            Well, I don't really know if any 3.4 guys with the rksport headers. Most guy for Pacesetters I believe because of cost. But the 3.8 guys al get leaks. And yes a T/A or formula rear will work, just don't get one with traction control
                              well i found pacesetter headers for 3.4L at Summit Racing part number PSM-70-1208 about $200 if i do these and a high flow cat at the same time would it be worth paying someone else to do it or should i do the headers myself and have someone else put on the cat
                              RedlineVSix
