here is the signs when I try to start up the car I have to continue to turn the key for it to start could be the starter. Then when it starts up the car will idle itself up to different levels without me stepping on the gas I also have to give it some gas to make it start sometimes. I have no check enine light so I think its either my fuel pump or starter or maybe the car needs a tune up. What does these signs sound like to yall camaro owners
Somethings going out on my car help
Re: Somethings going out on my car help
Originally posted by eric v6 View Posthere is the signs when I try to start up the car I have to continue to turn the key for it to start could be the starter. Then when it starts up the car will idle itself up to different levels without me stepping on the gas I also have to give it some gas to make it start sometimes. I have no check enine light so I think its either my fuel pump or starter or maybe the car needs a tune up. What does these signs sound like to yall camaro owners
Does the engine crank (turn over) consistently??? If so, starter is good.
If it cranks but won't fire then maybe fuel pump, or something else.
You need to answer first in order to diagnose any further.
Crank or no crank???
yeah the engine cranks up but I have to have my feet on the gas and pump it while Im starting the car sometimes the car just fires right up without me having to do so because I have remote start. I thought if the fuel pump was going out that could happen on start up. I just like getting in my car and not having to continue cranking up the car its embarrasing to drive such a nice looking car and when you get in it the car dosen't start up on the first turn it takes about 3 to 5 turns for the car to start.
I was also wondering could it be my spark plugs since I haven't replaced them yet
Originally posted by eric v6 View Postyeah the engine cranks up but I have to have my feet on the gas and pump it while Im starting the car sometimes the car just fires right up without me having to do so because I have remote start. I thought if the fuel pump was going out that could happen on start up. I just like getting in my car and not having to continue cranking up the car its embarrasing to drive such a nice looking car and when you get in it the car dosen't start up on the first turn it takes about 3 to 5 turns for the car to start.
i think it could be the fuel pressure regulator. or just a fuel issueHeady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
