If you would get the Hypertech Programmer what temperature should I program the fans to kick on? I have a 180 degree thermo.
Hypertech Programmer and temp to turn on fan
SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)Tags: None
Maybe I should re-phrase my question.
The stock computer setting is to turn the fans on at 210-215 degrees with a 195 degree thermo. Since I have a 180 degree thermo now, and since the hypertech allows you to reprogram the temperature at which the fans come on. What temperature should I program my fans to come on with the 180 degree thermo?SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
The HPP3 only gives you 4 choices for fan turn on/off temps: Stock, optimized for 195 degree t-stat, optimized for 180 degree t-stat and optimized for 160 degree t-stat.
You don't pick the fan temps, you just tell the HPP3 what t-stat you have in the car.
If you have the HPP3 check out page 9 of the installation instructions. It tells what the temps are for all of the 4 choices.2002 Camaro Coupe<br />Navy Blue, A4, Y87<br />Whisper Lid, Raised Air Box<br />SLP Bow-Tie Grill, HPP3
Ok, thanks for the info. I actually don't have the Hypertech yet. I am considering getting it when I do my gear swap so I can recalibrate my speedometer and shift points.SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 day ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...3 weeks ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...3 weeks ago
