anyone got a list of everything we are supposed to lube when we do our oil change? grease fittings, hinges, etc. maybe a website w/pics? thanks! [img]graemlins/burnout.gif[/img]
Lube chart
Hit the grease fittings on the front suspension (there are 2), plus any you might have on aftermarket suspension components (I know BMR's tubular LCA's have them). Check all your fluid levels (washer fluid, power steering, coolant, trans, etc.). Check your serpentine belt for cracks, etc. Check hoses for wear & so forth. Check your tire pressure as well. While you're at it, check all your lights to make sure they are all in good working order. Check your rear diff lube as well.2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
