My tensioner is shot. I've seen alot posted on the 3.4 but havent seen much on the 3.8 and the Haynes manual has no info about replaceing it. A few ?'s I assume the alternator has to come off are there any other surprises I'm gona run into? I have 148k on my 98 firebird so I think I'm gona replace the water pump while I have it torn apart. Is there any gaskets or other things I'll need or should replace? What kind of time should I expect to spend replaceing it?
3.8 tensioner
I do not think you need to pull anything to change the tensioner. It should just be a matter of removing the belt, unbolting the bad tensioner, and then bolting the new tensioner on. Just remember that the tensioner is reverse-threaded. ;)1996 Camaro w/ Y87 package. T-Tops, purple, loaded. Custom painted salad-shooters with Mirage paint.<br /><br />(It\'s my girlfriends car!)
Well it turned out to be alot easier than I thought. Had it off in 20 minutes. Just 2 bolts and the one to the alternater. Now I have to find someone open on a Saturday that has the 2 plastic pipes going to the block and water pump.98 bird <br />160,000 miles<br />13\'s? Just happy it\'s starts every morning. <br /><br />Traded in @164,000 On a 2001 Formula
