So i think it might be an alternator issue. 87900miles on a 2000. Its weird cuz it doesnt happen all the time just every now and then just on one drive. but happens on each drive. anyone delt with this before?
headlights dim while brakeing
Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.Tags: None
Re: headlights dim while brakeing
here is how i check to make sure the alternator is good, start the car get out while car is idling take off the positive cable on the battery if the car dies alternator is bad,if you take the postive cable off and it does not die get in the car turn headlights on turn heater on radio ect.. and if you turn everything on and it still dont die alternator is good but if you turn everything on and the car dies that means the alternator is weak.good luck
I don't think its much of an issue. The 3.4 I use to own had some smaller pulleys on it, the amperage would drop to a nose hair above the red. The head lights dimmed a bit but it still gets its 'charge' from the driving. You can check your alternator's output at an autozone, you have to put down a deposit and they let you use some voltmeter or something. Once you're done you get your deposit back.Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
Originally posted by Fbody3400 View PostI don't think its much of an issue. The 3.4 I use to own had some smaller pulleys on it, the amperage would drop to a nose hair above the red. The head lights dimmed a bit but it still gets its 'charge' from the driving. You can check your alternator's output at an autozone, you have to put down a deposit and they let you use some voltmeter or something. Once you're done you get your deposit back.
Originally posted by 2002steen View Posthere is how i check to make sure the alternator is good, start the car get out while car is idling take off the positive cable on the battery if the car dies alternator is bad,if you take the postive cable off and it does not die get in the car turn headlights on turn heater on radio ect.. and if you turn everything on and it still dont die alternator is good but if you turn everything on and the car dies that means the alternator is weak.good lucksigpic
Yah i really didnt want to try that whole biz suggested by 2002steen.Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
DO NOT DISCONNECT THE BATTERY WHILE THE CAR IS RUNNING. That is an old trick to get people to buy a new alternator. It can damage the alternator and the sensitive electronics in the car. The car will always die when you disconnect the battery because the alternator depends on power from the battery to produce a magnetic field to generate current. By disconnecting the battery you break the circuit. No battery, no alternator, no spark, and the engine stalls.
You can use a voltmeter to check the voltage while the car is running. It should be about 14-15 volts at the battery terminals. Our cars have an inherent problem with lights dimming sometimes when the brakes are applied. You will also notice the voltmeter drop and then come back up. It seems to happen more when there is a heavier electrical load.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
so this is probably no big deal then.?Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...2 days ago
