my AC controls are scccreeewweedd. when i got the car, the air would blow from the defrost and floor, but not the vents. now it doesnt blow at all, thou the compressor does come on when the switch is moved anywhere besides the "off" position. pretty sure the vacuum connection stuff is messed up...any easy way i can get the vacuum controls corrected, without payin 50 bucks at the local garage to have it done? not only do i not have air, but on a humid rainy day, i have no defogger/defrost. :bs:
easy fix for AC?
Re: easy fix for AC?
i actually cant hear the air blowing. sittin with the car runnin, when i cut the knob on, i can hear the compressor come on, but no air sound. with the radio all the way down i can hear a whooshin sound, like the vacuum sound.Last edited by 95astrovan; 04-02-2008, 08:46 AM.
Sounds like you blower went out or got disconnected, that's an easy test and fix. The defrost occurs because there is no vacuum, so the default position is defrost for safety reasons. You can take out the HVAC controls and check the vacuum lines, and then check the lines under the hood. Also you can check the actuators. A handheld vacuum pump is a huge help here.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
I believe that for the climate knobs, you just take off the trim plate around them and the radio, then undo the screws. On a Cavalier I used to have, the little rotating vacuum control went bad and was leaking. I got a "new" one from the junkyard and that fixed the problem. At least though, listening around behind the controls may help you determine the source of the leak.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
