five long months - FirebirdV6.com/CamaroV6.com Message Board
five long months
  • five long months
    My firebird is going to sit for five months untill i get back home. What should I do so it is happy when I get back?
    Re: five long months
    where ya going?
    fresh fluids...and a fresh charge on your battery, sunlight
    my other truck has a 50 cal mounted on it
      Iam going to san antonio tx
        I would just change the oil, put it on something to get the tires off the ground, and then disconnect the battery. Five months isn't that long of a time. It'll be fine when you get back.
          agreed, but dont change the oil until you get back
          doesnt really matter though, like you said 5 months is really nothing
            Personally, I would change the oil if the current oil is at all old. It gets acids and stuff in there, you wouldn't want that sitting for months on end. If you changed it just recently, then I'd leave it.
            Also, if it's going to be in a garage with electric access, you could get a trickle charger the keep the battery charged, and keep all of your radio settings and such. Plus then the PCM won't have to re-learn everything when you get back.
              Dump some fuel stabilizer in the tank and fill it up. When you do park it, make sure the car has been running for a while to be sure any condensation has evaporated. The absolute worst thing to do is have someone start it up and idle it for a few minutes every so often while your gone.
                its bad for the exhaust, but running it for more than a few min (15) will do good
                • Andy H
                  Transmission removal help!!
                  by Andy H
                • 2.8 Bird
                  Abs inop
                  by 2.8 Bird
                • fishin
                  by fishin
