New season, Same Old Rattles!!! - FirebirdV6.com/CamaroV6.com Message Board
  • New season, Same Old Rattles!!!
    I've read several posts about the different rattles that our cars make, however after a year I'm still having rattles. The main rattle is at low RPM's, usually when I'm pulling into my driveway. Sounds like it's coming from around the tranny/cat area. I have put a new cat on and when I'm under the car and bang on the exhaust, there is no rattle. For those who have had heat shield rattles, can you describe under which situations they occurs. And have any of you had tranny rattles?
    [ April 17, 2004, 10:08 PM: Message edited by: CanadianCamaro ]
    1998 Camaro M5, Sports Appearance Package, K&N,CAI,Whisper Lid, Dynomax Superturbo exhaust,Carsound Converter.<p><a href=\"http://members.cardomain.com/canadiancamaro\" target=\"_blank\">http://members.cardomain.com/canadiancamaro</a>
    I just bought my 00 camaro and if your talking about the same rattle I here in the same place, I dont know. But your right it only rattles at the low rpms and only if im going around 25 or so.
      i here that rattle too around 25 but it is only when my car is cold??? anybody know?
      2000 3.8 A4 Pewter Camaro
        Mine happens when the engine is hot and happens at even lower speeds (ie. if I just let the car role using the clutch)
          I had that problem for a while and found out it was a few rocks in between some heat shields. Also, try crawling underneath your car and see if anything looks loose. Grab piecs that look like they shouldn't move and see if they wiggle ANY! The slightest bit of play can make a lot of noise.
          Good luck.
          95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
            I'll see what I can find next time I'm changing my oil or something.
              Today i was underneith my car and I knoticed that the Y pipe sits pretty close inbetween the tranny and the oil pan. I'm thinking that, that might be the cause of the rattles.
                I have the same rattle on my 99 A4. Usually at idle or low speed (&lt; 20). After doing searching for other threads I figure it is my heat shield or cat. I went under the car and can't see where the heat shield is rattling. I need to check the cat.
                Welcome to the club though. It is quite annoying hearing it and not being able to find it!
                SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
